Buffing wheels http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=4980 |
Author: | Iplaytheoldies [ Wed Feb 08, 2006 2:26 pm ] |
Post subject: | |
Where is the best place to get Large buffing wheels? (12",14", or 16") I'm going to rig up my own buffer with an industrial baldor motor and a 10:1 high torque gear reducer and I would like to use a large buffing wheel. The output on the reducer is a 3/4" output so if there is someplace that has a solid 3/4" arbor, then I wouldn't have to modify anything. Has anybody tried this yet?? Thanks for your help. |
Author: | tippie53 [ Wed Feb 08, 2006 3:54 pm ] |
Post subject: | |
http://www.caswellplating.com/buffs/index.html try this place. john hall |
Author: | crazymanmichael [ Thu Feb 09, 2006 1:14 am ] |
Post subject: | |
i second john's suggestion of caswell. however i doubt the wisdom of using a high torque motor drive on your buffer. low torque/power will help prevent burning your finish; if you apply too much pressure the buff stalls. with a high torque drive the wheel will continue to spin and you can very easily burn your finish. i only use a 1/3 hp, 1750 rpm motor reduced 2:1 yielding 875 shaft rpm with 12" buffs. works fine. |
Author: | Iplaytheoldies [ Thu Feb 09, 2006 11:57 am ] |
Post subject: | |
thanks for the suggestion |
